Had an idea for ark pro line.
**edit** I got a rough rendering of the idea but the geometry is off. I hope this is enough to explain the concept
The idea is like the normal arkpro ultra, but the head can be rotated down to form a 90⁰. Now, when the head is rotated to 90⁰, there is a small screen that is revealed above the selector switch. That screen denotes two numbers: distance and temperature.
So the other addition obviously would be an IR sensor and a laser feed back sensor to determine distance and temperature.
I think these features would be incredibly useful and you could remove the UV light because it doesn't get used that much anyway.
Also maybe when you rotate the light to 90⁰, you unlock a medical moonlight mode. That has a .1 or .25 lumen output. Now, the light becomes useful for emts, law enforcement, and firefighters to take temperatures, and check pupils.
