Chapter 03——The First Crossroad
Story Preview
With ArkTac Ultra now guiding them, the two princesses reach a crossroads with three possible routes. A clue is waiting nearby—but only someone willing to look from a different angle will find it.
  1. Three Roads, One Destination
  2. Finding the Right Angle
  3. A Clue Beneath the Roots
By morning, the storm clouds had drifted farther across the mountains, leaving the forest damp and quiet. The three travellers followed the valley until the trees opened onto a broad clearing.
Three roads stretched away from it.
The first climbed between dark rocks. The second curved beneath a canopy of tangled branches. The third looked easiest, but its surface was scattered with stones and disappeared behind a wall of mist.
ArkTac Ultra studied each route. “We should not choose by appearance alone. The wrong path could take us deeper into the valley.”
ArkPro raised her light toward the distant slopes, checking the shape of the terrain. “The ridge beyond the first road may connect with the old route, but I can't see what lies beneath the overhang.”
Oclip was already examining the ground near the crossroads. “Then let's look closer. There may be a marker we've missed.”
The knight nodded. “Good thinking. I'll watch the open paths. ArkPro, keep an eye on the ridge. Oclip, see what you can find around the roots and stones.”
Oclip moved toward an old tree whose roots curled over a low section of rock. At first, the surface looked blank. She leaned closer, but the narrow space beneath the roots remained in shadow.
“It's too low to see from here,” she murmured.
Instead of moving the whole light repeatedly, Oclip adjusted its head, tilting it downward to reach the awkward angle. Then she rotated the clip, redirecting the beam along the underside of the roots.
The light followed the shape of the ground as she changed position. A thin line appeared in the dust.
“There!” she called.
A small carved mark had been hidden beneath the overhang. It was not a complete map—just a simple symbol, partly covered by soil and fallen leaves. But its shape matched a mark on one of the old stones beside the first road.
Oclip grinned. “Sometimes you don't need to search farther. You just need to look from somewhere else.”
ArkPro came over and compared the two markings. “The same symbol appears on both. It must mean something.”
ArkTac Ultra examined the surrounding paths before looking back at the discovery. “And it points toward the first road.”
The three gathered around the old stone. ArkPro used her light to examine the wider area, checking how the marked route continued beyond the clearing. ArkTac Ultra watched the distant trail, making sure the valley remained safe while they studied the clue.
The carved symbol was simple: a curved line ending in a small notch. It appeared again on a stone partly buried at the edge of the uphill path.
“Someone wanted travellers to find this route,” ArkPro said.
“Or to remember it,” the knight replied. “These markers may belong to an older road.”
Oclip brushed the last leaves away from the carving. “Then this is our road.”
ArkPro looked at her companion with quiet approval. Oclip had been the first to notice the mark, but it was her patience—and the way she adjusted her light to reach a difficult angle—that had made the discovery possible.
The princess stood a little taller. “I told you there was something here.”
“I never doubted you,” ArkPro said.
ArkTac Ultra turned toward the chosen trail. “Then let us follow it while the weather holds.”
They left the crossroads behind. Ahead, the trees grew thinner, revealing a deep valley beneath a sky that was beginning to darken again.
To Be Continued
A low rumble rolled across the mountains. Far ahead, clouds gathered over the valley—and the old trail led straight into them.
Join the Journey: Have you ever found something important simply by changing your point of view?
Next Chapter: The Storm Is Coming
