Story Preview
Still following the faint trail from the forest, Oclip 2 Pro and ArkPro face an unexpected danger after nightfall. A mysterious figure steps from the darkness—and the journey home gains a guardian.
A Sudden Threat
The faint light ahead had seemed close when the two princesses first spotted it. Now, after what felt like an endless walk beneath the trees, it had vanished behind a wall of darkness.
Oclip 2 Pro slowed beside ArkPro. The forest had changed. The wind moved through the branches with a low, restless whisper, and somewhere beyond the trail, stones shifted against one another.
“Did you hear that?” Oclip asked.
ArkPro raised her light and studied the path ahead. The beam revealed a narrow stretch of earth bordered by steep roots and loose stones. Beyond it, the trail bent sharply around a rocky rise.
“Stay close,” ArkPro said. “We don't know what is moving out there.”
A sudden crack rang through the trees.
A section of the trail gave way. Soil and stones slid down the slope, sending a cloud of dust across their feet. Oclip stepped back just in time, but the safer ground behind them was now partly blocked.
For a moment, neither princess moved. The darkness seemed to press in from every side.
The Guardian Knight Appears
Then a steady beam cut through the trees.
It was narrow and bright, reaching beyond the fallen stones to reveal the shape of the trail ahead. A second, broader light followed, spreading across the ground and the surrounding trunks.
A figure emerged from the ridge.
He wore dark, hard-wearing armour that caught the light along its edges. In one hand was a compact multi-light device; his posture was calm, alert, and unmistakably protective.
“Step away from the slope,” he called. “The ground is still shifting.”
The stranger moved closer, checking the distant path with his Spotlight before switching to Pure Flood to examine the unstable ground around the princesses. He used the controls with quick, deliberate movements, changing the beam to match the task rather than wasting a moment.
A loose rock broke free above them. The knight turned toward the movement and triggered a brief Instant Strobe warning. The sudden burst of light startled the danger away from the immediate path and gave the three of them a moment to move to safer ground.
“Are you both unharmed?” he asked.
Oclip looked him over, curiosity quickly replacing her fear. “You appeared just in time.”
“I was watching the trail from the ridge,” he replied. “The storm has made this valley unpredictable. You should not travel through it alone.”
A Promise to Bring Them Home
ArkPro stepped forward. “We are trying to find our way home. We don't know this forest, and every path seems to lead somewhere unfamiliar.”
The knight lowered his light slightly. “Then you need a guide who knows how to travel through the unknown.”
“Do you know the way?” Oclip asked.
“I know these valleys and the old routes beyond them. I cannot promise the road will be easy,” he said, “but I can promise that I will do everything in my power to bring you both home safely.”
He placed one hand over his chest and bowed his head.
“I am ArkTac Ultra, guardian of these roads. By my honour, I will protect you and guide you until you reach home.”
For the first time that night, ArkPro allowed herself a small smile. Oclip's shoulders relaxed, and she stepped closer to her new companion.
“Then we should keep moving,” she said. “Before the forest finds another way to surprise us.”
ArkTac Ultra turned toward the trail. His Spotlight reached into the distance, while the softer spread of Pure Flood kept the uneven ground around them visible.
Together, the three travellers left the fallen path behind. They did not yet know what waited beyond the valley—but they were no longer facing it alone.
To Be Continued
Beyond the trees, the valley opened into three winding paths. One was marked by old stones, another disappeared beneath tangled vines, and the third led toward a distant rumble of thunder.
Join the Journey: What would you have done in the princesses' place when the trail suddenly began to collapse?
Next Chapter: The First Crossroad
